Help
Maytag MGR5755ADQ gas oven will not ignite. Get F3 code. This is the 3rd time I have asked for help and have not got a response. It seems other people are??? Please help, can’t afford a new oven or service man.:confused:
— Begin quote from barnz2000;145379
F3
or
F4 Open or shorted oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor if wiring is ok. See below.
AP4009456
I replaced the oven sensor as you instructed. I turned the oven back on and am no longer getting the F3 error code, instead I am now getting a new F1 error code. Oven still won’t light. Acts like it will try and never does light then beeps and gives F1…Any suggestions? Please Help!!!
