Help
I need some information
My washing machince is leaking water at the front bottom
Does anyone know what this is and how to fix
It is probably the pump. This video will show you how to open it up and check it out. If the problem is not obvious, bypass the lid switch and run it with the cabinet off to observe where the leak is coming from.
