Hot water not coming in washer
The hot water is not coming in the washer but the cold water works and I have already changed the inlet water valve and that did not work. Can you tell me what may be my problem?
Thanx, 504 boy
If you replaced the water valve, and are sure you checked the hot water hose coming into the washer, that water flows out of it, when it is unhooked, it would then most likely be your temperature selector switch. I imagine you have one. The parts list calls it a rotary switch. The part # is WH12X999. Tom
