No Hot Water Coming Into Washer
i HAVE HOT WATER COMING TO THE LINE BUT NOT INTO THE WASHER. I have cleaned the screen and replaced to no success. What should we do next???
Use a meter to see if 120v is coming to the hot water valve when the timer is calling for hot water. If so, the valve is defective and should be replaced.
If not, the temp selection switch or the timer is the issue.
