I have a 6.5 yr old Kenmore washer - model #23812100. Problem: the hot water will not stop running into the tub. All other cycles work fine. Normally, when you push the Cycle Selector Control knob in the water will shut off. At this time, when you push the control knob in the cold water will stop but the hot water will continue to run into the tub of the machine. Also, water ran out from under the machine onto my floor.
Is this due to the constant running of water into the tub? Is there a part that would eliminate the problem of the hot water not shutting off? Does it have something to do with the Cycle Selector Control Knob? The water continues to run during all cycles. The spin cycle works fine.
Select hot/hot or warm/warm and start a cycle. As it’s filling, unplug machine. If it continues to fill after the machine is unplugged, you’ll need to replace the water inlet valve. Remember to shut off water at th source, and unplug the machine before making any repairs.
It isn’t so difficult that the average person can’t do it. If you know your way around a screwdriver and a wrench, you can do it. We’ll talk you through the steps.
Well done! I’m glad you got it.
I was looking through google desperatley to find a way to fix the washers problem that I had NO:confused: idea about nor did I have the slightest:( inclination of what was wrong. I found this answer at 439am and my washer is fixed:) , happened to have an old one that had the part I needed! Lucky me huh!! So I had to register here just to say thank you so much for all the good answers!! And not even my question! Yes, Im a but excited and got carried away with the (!!!) lol thanks again, Brandell Kays
