Hotpoint Washer Making Noise and Won't Drain
Washer been very loud lately and now won’t drain. Looked for drain plug or filter area at bottom of washer but don’t see a plate. I suspect it might be the pump, but dont’t know if a pump would make this much racket. Help please?
[SIZE=3]If something is in the pump it can make a heck of a noise or you could have two separate issues. [/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3]Check for a clogged pump first. [/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3]Remove all the water and take the hoses off the pump. Be prepared for water because you can’t remove all the water from the tub. [/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3]Then check inside the pump for anything that will block water or the pump. [/SIZE]
http://www.appliance-repair-it.com/clothes-washer-repair.html#GE
Thanks for your reply. Took front off the washer and removed pump. Nothing clogged in pump except for some lint around impeller. Seems to be okay, but ordered a new one (48.00) after going to all the trouble. Keep looking around for a belt, but this type doesn’t seem to have one. Is there anything else I should be looking for?
— Begin quote from applianceman;163150
Clothes Washer Repair Guide
[SIZE=3]The washer has a belt but it doesn’t have anything to do with pumping the water out. I hope the pump gets you back going! [/SIZE]
