Wahser won't drain humming noise
My washer agitates properly, but it just hums when it is supposed to drain. What should I check for first?
Check the pump for some type of obstruction, maybe a sock or underwear.
If you need more info please post a complete model number.
— Begin quote from sidfink43;167452
Found a sock in the pump, humming noise from motor
