How do I change the water actuator on Frigidaire Side-by-side
Saw the other posts on this subject,but different model number/makes. Is it the same procedure to access/replace the actuator? (Seems everything is breaking at my house!) THANKS!:o
Remove the label-module cover (#14 on the diagram) and four screws holding the front cover. The rest is pretty similar.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=1257472&&model_id=5155418
