I need to install new sensor. It has 2 prongs, but only 1 (green) wire is
showing inside dryer. Is there another wire? If so, how do I get to it? Which wire goes to which prong? Thanks so much for your help.
— Begin quote from thefixer;119880
There is another wire, it is blue in color. It does not matter which wire goes to which terminal on the sensor bars. You access it by removing the front panel. The sensor bars are mounted to the bulkhead, which is the piece the front of the drum is riding on. Below is a picture of the sensor bars, and a link to the parts breakdown of the unit.
[MODEL]LDE9304ACE[/MODEL]
Thank you so much for your help. Took a minute to find screws holding front panel. Installing sensor was a snap. You will be my go-to site in the future when I want to fix something myself.
