Trying to open. Is it simply a matter of prying the lid up?
Hi.
To raise the top on this model you need to remove two screws
at the bottom of the front panel and pull it out.
Then using 5/16 nut driver remove two screws holding the top in front (one in each corner).
Lift the top.
Simon.
