The plastic dowel on the left side panel that holds the drawal cover broke. I ordered a new side panel, but the old one attaches to the cabinet wall with fasteners that have rounded heads. How do I remove the old side panel? What tool do I use?
Thanks,
Dave
Here is the parts break down.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=JFC2087HRS
Perhaps if you identify the parts in the parts breakdown someone may be able to help.
Often if it is just a rounded button you can pry it up/into the unit with a small screw driver or a knife.
This may also help
http://www.applianceaid.com/frig_support.html
