How to repair Oven door latches?
Removed the oven door to replace the electronic control board, now one of the latches is loose and can’t put the door back. I need some assitance. Thanks,
You say one of the latches is loose, do you have a locking clip to hold the latch open. Can you send a picture of what you are dealing with on the door so I can help you with this. A picture of the door and the latch will be great. Thanks.
