how to replace/check Pba main board?
After testing all the wires for continuity, the only thing left is main board. Since the fridge side freezes every week after a good defrost on the fridge side this morning i checked the coils again since i assembled it back (last night) after defrost. The coils had very minimal ice on some part of it.
Here is what i found out this morning after watching the display on the freezer door: (After opening the fridge coil compartment for inspection ) Temp in the freezer and fridge went below set temp. Temp has been fluctuating.
Last night after i tested everything ( except the board ) this morning this is the only issue i have seen. Motor,fan, compressor etc working just fine. Also, when i opened the fridge door i could hear water running, but no leak or anything??
Any input greatly appreciated.
