Hi,
Don’t have the funds to call a repair person and need to replace the felt glide assembly on my stackable gas dryer. How do I access this part? On publication 5995326377, it appears I need part 20 and possibly #21. Do I get to those parts through the front door panel? Do I have to do anything with the control panel to get access to the glide assembly? Help! Just need to know how to get there. Thanks much in advance.
Yes, you referred to the correct parts and you do have to remove the front panel in order to access them. You can find the complete instructions in the [AP2143044](http://www.frigidaire.com/tip/servicecd/Content/Laundry/5995373155.pdf"]Service Manual[/URL].
The part number for the upper felt seal is AP2150497
The part number for the lower felt seal is [URL="http://www.appliancepartspros.com/partsearch/ctrfs.aspx?part_id=2143044&&model_id=115703&diagram_id=248563)
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=248563&&model_id=115703
