Frigidaire Dryer Drum ??
I need to know what part # to replace the felt material that is attached to the front panel that the drum rotates on. Is it AP3579413 & AP3220737 that I need. Also, need the plastic piece that is attached to the drum itself that slides on the felt piece. Each piece is approx. 65" in length. Thanks!!
You found the correct part numbers for the upper and the lower felt seals. The part number for the drum glide is AP2107932 and you have to order two of them.
Thank you, my wife contacted them yesterday & that is the part # we received today. Man the shipping is fast,1 day later. :slight_smile: :slight_smile: :slight_smile:
I repaired it a few hours ago. The glides seem not to snap in place perfect. Two holes in the drum are a little bigger than the prongs on the glides so I put a dab of the felt glue there to help hold it in place.:eek:
Also, I noticed a yellow piece attached to the top of the front panel that is not doing anything. What is it intended for,or maybe it is missing a piece ??
