How to test Dryer motor accurately
I replaced burnt harness part# 131484100, but when I made the first test motor ran, second start motor just hummed got hot and I could smell it.Could it be a bad motor which cause the original problem.How could I test?
Most likely the motor has gone bad. If you would like to test it, look for the wiring diagram behind the cover under the dryer.
