I just moved and somehow during the move a leak was created inside the freezer door. The boys were a little rough when they moved the fridge. After I hooked the water up I noticed that there was a small leak coming from the hose under the freezer door. When water is dispensed the leak drips a lot faster. The water is leaking down the hose and appears to be coming from inside the door. How do I access the hose so I can find out if there is a puncture or if the hose was pulled loose somewhere? I figured out how to remove the control panel and checked the hose I could see there and do not have any water leaking there. The inside door panel seems to be glued on. Thank you for any help that you can provide.
Related topics
Leak near water dispenser | 1 | 576 | February 18, 2016 | |
water leak inside freezer door | 1 | 2682 | February 19, 2010 | |
Water leaking out of freezer door | 11 | 3025 | November 14, 2013 | |
pump leaking water and no water in door | 6 | 2403 | February 28, 2011 | |
water leak | 1 | 1009 | July 3, 2011 |
