water leak
when we use the water dispenser to fill up a glass of water water runs down the tube and drips onto the floor.
The water is running down the tube that goes up through the hing and into the door. It doesn’t drip while its not in use, only while filling a glass.
i removed the panel/trim around the despenser hoping to pull the tube out and replace it, but there must be something inside the door the tube passes through??
what do you think is leaking and how do I get inside the door it self to repair it
