The washer quite working today for the wife and when i got home i took the front cover off and pluged it back in and turned it on and it squaled alot tried to run slowed down and shut its self off. i pulled the belt off and the motor turn freely by hand the transmission turns as easily as its going to with the tub half full of water and the pump turns but it sounds like the bearing is shot and it feels ruff. i looked in the parts section and there are 3 differnt options for the pump, which one do i need? can just the bearings be replaced?
Hi,
No you can not replace the bearing in the water pump.
When I look up your model number using my local parts distributors site I come up with factory part # 21001873 for your water pump.
I think any of the three listed would work, but I think 21001873 should be the newest version.
