The ice dispenser and water dispenser in our Whirlpool side-by-side freezer door does not do anything -nothing comes out and no noise when you depress the levers.
The indicators for type of ice and lock status do light up, and you can ‘lock’ and ‘unlock it’.
Model ED5FHAXVY03
Repair technician informed us that the wire powering the dispensers had broken at the bottom of the freezer door (where it connects to the body of the freezer.)
He said the wire had already broken and been repaired previously, and now it is too short to patch it. And that the door is molded together and you can’t take it apart to replace the wiring.
It appears that it could have been assembled that way, but if there was a way to get at the wiring harness, it would have to be from the inner door panel most likely.
If you move the gasket aside, you can usually tell if there are assembly screws that hold the inner door panel to the door.
Yes, you could use a fish tape or wire to pull the new harness through to rewire it.
We had another repair guy out today and he said that looks like the right part and he should be able to fish it through the door.
However he pointed out that there are actually 2 wire harnesses that run out to the freezer door, and suggested we consider replacing both of them. (They both get stressed whenever you open and close the door so seems like the other one is pretty likely to break also.)
I want to order the other wire harness but not sure which part it is.
but hard to tell for sure because the diagram doesn’t show whether that wire runs out the bottom of the freezer door.
But this one is for the ice motor which is in the freezer door so it seems like a likely choice.
attached is a photo showing what the ends of the wire harness look like - i labeled the one I have confirmed is correct, and also put in the part number for the one I’m not sure about (with question marks)
