Ice & Water Dispenser Not Working
For several months the ice dispenser has made a loud buzzing noise when working. I assumed it was a solenoid problem. Yesterday, the dispenser stopped working entirely. To be safe, I’m considering ordering the following parts: control board, solenoid and dispenser switch. If I’m going to attempt to do the replacement myself, I’ll need some pretty detailed instructions on how to proceed. For example, I assume I access the parts from the front but how do I get the cover off? Pretty basic, right?
The alternative is to get a new refrigerator since I imagine having this 11 year-old model repaired by a professional would cost $200 to $300.
The front cover pops right off, get a putty knife and slide it up from under. once you get that off, take out the 4 screws in front of you. Remove the pad you press your glass against for ice, it is attached to a square black plastic piece that just snaps in. now pull the whole assembly forward enough to get disconnect the wire harnesses, and remove the rest of the way, if you get hung up let me know. Once you get the front face plate off, you will see exactly what I’m talking about. This is a real easy repair
That was a lot easier. I know you know what I’m seeing after having removed the face plate and the 4 screws but, for the benefit of others who may have this problem in the future, here’s an image:
http://additionalinfo.synthasite.com/GE_Ice_and_Water_Dispenser.php
So, what parts should I order and how do I install them?
Thank you.
I’ve received the parts I ordered from you and replaced the circuit board. Fortunately, i also ordered a solenoid since the old one appears to be rusted out. How do I gain access to remove the three screws that hold it in place? Does the plastic part (No. 58 on the drawing) into which the circuit board is inserted come out or does it just drop down?
Water comes out of holes in top tray on my washer and runs over the top? We have replaced the pump & belt to no avail.
