Ice dispenser and Water working icemaker not
My ice maker does not seem to be filling with ice. Normally you can hear the water running into it, but not lately. It looked like a little water had run into it and stopped. Then the arm never rotated it out. My husband took it apart and said it looked like a little piece of ice was stuck, he then freed it and since nothing else has happened. Any help would be greatly appreciated. THANK YOU
add water with a cup directly into the cube compartment. If it works for that load it is either a stopped up supply line or there is no water getting to the ice tray.
Hi Shelly,
You can find the complete instructions in one of our previous posts: http://forum.appliancepartspros.com/refrigerator-freezer-repair/8566-water-ice-maker-quit-working.html
After you will do it, post the results.
Here are the break down diagrams for the Whirlpool refrigerator http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=129673&&model_id=503694
Hi Gene, I just now got your message. I tried what Owen said with putting the water in and seeing if it would freeze and rotate the ice out and it did not. After that I was just going to go buy another ice maker.
Thank you both for your input.
Just in case, the part number for the ice maker is AP2984633
Keep us posted.
