Refrigerator will not dispense ice. Water dispenser works fine. Light dims when you try to get ice. I have replaced the control panel and same problem exists. Any recommendations? Could it be the ice maker?
I replaced the dispenser board. This didn’t change anything. Ice still will not dispense, but water works fine.
[SIZE=3]The main board is bad, replace it. [/SIZE]
washer not draining,understand small items can get in behind the seal and cause this (happened once before). have removed the white outer door and unscrewed the black plug, but nothing there. how else can i check for a clog? any advice is appreciated. live in germany and will cost 80euros for repair person to just show up
found out via bosch toll free number that 99% of time washer WON’T DRAIN if load is TOO SMALLl and or too much detergent is used. i had tried to wash 3 cleaning rags (used too much detergent,too) before going away for 2 wks and seems that was the problem.(who knew?) put in a full load w/one T. of soap and worked perfectly. very important to NEVERr use more than 2 Tablespoons of soap in a H E machine / 2 T. would be for a full load of heavily soiled clothes.
