Water does not dispense
The water on the door does not dispense. Occasionally it works but not for long. When it does not work the ice maker does not dispense cubed ice. It always crushes it. Is it as simple as replacing the board?
Sean
Hi Sean,
If the dispenser lights go dim when you push the release lever then the main control board is the culprit.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5210965
The light does not go dim.
Sounds like the dispenser control board is the culprit.
Not the board. Got the new board in today. No difference. Anything else to try?
Sean,
If the dispenser control board did not fix the problem then the solution is to replace the main control board. You can easy return the unneeded part if you ordered it from APP.
The part number for the main control board I posted earlier.
