ice maker and door seals not working
The 2 doors stopped sealing when they are closed. The seals around the doors are in good condition. The ice maker stopped making ice, no water going into the ice maker. I wonder if there could be a common problem to solve these problems.
Hi All,
I have a GE Monogram double wall oven and recently after using the top oven I noted the fan was still running and the oven was still warm (not cooking temp) several hours after use. I opened the main breaker for 20mins or so and after restoring power the top oven remained off. Since I really never need two ovens and the top oven is used 95% of the time i figured i’d just start using the bottom oven, which would technically be "new" until i could resolve the issue.
However after using the bottom oven the same issue occurred. The bottom would not shut off after use and would remain warm with the fan on. After resetting the oven again by removing and restoring power i verified that the buttons on the panel all worked. To do this i just pressed bake or broil on both the top and bottom oven and before pressing start i would press stop / clear. This would clear the bake or broil request and the screen would return to the home default display.
The failed component which is causing this issue must be common to both the top and bottom oven.
Any help or tips would be greatly appreciated.
Thanks!
Monogram Man
