I get no ice at all. The ice maker won’t run at all. The water dispenser works ok.
I am only getting 34 volts supplied to the icemaker. This is supplied from the receiver board. There is 115 volts coming into the receiver board and only 34 volts going out. The emmiter board light diagnostic check works ok., (2 flashes with a second delay while flapper door is open) and (LED on solid with flapper door on emmiter closed.) I have replaced the emitter and receiver board with the same results. I have downloaded the manuals here:
http://www.applianceblog.com/manuals/in-door_ice4322658A.pdf
Any suggestions, ideas, would be greatly appreciated. It’s hard to have a scotch on the rocks these days!
