My ice maker has stopped working.The tray had no water in it,I removed the ice maker from the freezer ,didnt see any obvious problems.I reinstalled it and checked it about 3 hrs later,but it did not fill with water .Checked it the next day and the tray did have ice in it but did not release it .(the ice is still in tray for about 7 hrs now).The Infrared lite seems to be working fine(blinks with flapper open ,then stays on with flapper closed).Any Ideas? Thanks Ray
OK From top to bottom on the harness plug I had white,yellow,black with white stripe,black,brown with white stripe,orange with black stripe. I jumped the black to black with white stripe. Nothing happened. The fact that there is no water in the tray(tray hasnt filled with water from begining of problem) would still be a result of a bad I/M??? Thanks Ray
Yes no water in the tray can be a bad I/M. When voltage is supplied to the I/M it first heats to harvest ice in tray. It will not send power to the valve until the gears have turned enough to tell the I/M the tray is empty.
Bad gears=no power to fill valve.
Thanks for your help. I will order the new ice maker, Do I need the whole IM or just the module?Would you happen to know the part # I need for this model(GS6SHEXNS00) ? Thanks again for your help,I will let you know the results.
