just replaced ice maker, it is going through cycles but no water is coming into the ice maker, I have water to valve but no water making it up to the top of frig where it enters freezer, water dispenser is working fine, can the valve be bad?
Hi.
Most likely it is the water inlet valve 2188542
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=249273
Post the results.
Simon.
