I am trying to remove my ice maker and cannot figure out how it comes out. There is one screw on the bottom that I removed, and two tabs on the top. I cannot get it to come loose from the tabs on the top. I am sure its real simple, but I cannot seem to find a detailed instruction on the internet. any help would be appreciated.
SublimeMasterJW said:
Remove the filter then the 2 phillips screws up in the filter housing so you can pop the top. Next get a putty knfe and fanagle the spring clips holding down the top. Then get the 2 screws off that hold the front on. IMPORTANT: raise up 2 inch’s on the panel to get it off. The lid switch can now be dealt with.
i have a stacking front loader. i took out alls screws, the filter but nothing is budging? any other thoughts?
