ice maker
I Have A Side By Refigerator/freezer With Ice Maker And Water Dispensor.went Out Of Town Turned Off Ice Maker To Empty Ice Bucket Turned Ice Maker Back On When We Got Home Two Days Later Still Didnt Have Any Ice Water Still Works I Can Make Ice Maker Go Through Cycle By Turning Off And On But No Water Goes To Ice Maker Took Line To Ice Maker Off And Blow Air Through It Unplugged And Cleaned Fridge And Freezer Left Unpluged For At Least Four Hours So Its Not Frozen I Was Thinking Maybe The Water Valae Is Bad If You Can Help I Sure Would Appreciate The Help Model # Is La32223898
You may be aware of this already, but it took me some time to figure out. The forks that scoop the ice out of the cups are on a time delay, if they are forced to move manually then they will rotate a complete 360. Once the cycle completes, then the valve opens on a timer to fill the cups again. Try manually rotating those forks clockwise, and see if they continue to rotate. You should see h2o at the end of the cycle.
model#frs23h7csb80 i turned to make cycle i get water for ice every know and then but it will not eject unless i make it start to cycle manually then it takes another day or two to get any more water in ice maker
