The ice maker on my frigidare side-by-side is not making ice. I am still getting water at the water dispenser and if I pour water into the tray manually it will eject icecubes in the normal time. I think the water valve may be bad, although it is still suppling water to the water dispenser. is there a reset switch?
Swap the wires between the ice maker and the water dispenser solenoids at the water inlet valve. Push the water dispenser lever for a few seconds and check for water in the ice maker.
If there is no water, replace the water valve.
If there is water, replace the ice maker.
The water valve 241734302
The ice maker 5304458371
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5157949
Thanks Gene, but I already bought the water valve - so I will put it in. But I will try swapping the wires first.
You are welcome. Keep us posted.
Re: frigidare FRS23LH5DS0 side-by-side.
I replaced the water valve and the Icemaker - Still no ice? I have water to the back of the icemaker, but it is not filling the tray when I rotate the paddles to 7:00 o clock postion. What now?
Have you checked the water tube into the ice maker for any blockage and/or ice inside?
Yes, I checked the water tube up to the point where it enters the back of the refrigerator behind the freezer, and I defrosted the freezer to allow any ice inside time to melt (about and hour). Do you think it needs more time to thaw?
I would disconnect the ice maker tube (1/4") from the water valve and blow some air through the tube.
Thanks gene. Already started. Also, I hit the fill tube with a hair dryer and a chunk of ice slid out. I am re-connecting the IM.
Finally, there is water in the ice tray. . . . we’ll see.
Ice maker is back on line. Thanks again Gene.
You are welcome. I’m glad it’s up and running.
