Just replaced my ice maker and it will not work. I’m getting water to the back of the unit but not up to the tray. Can anyone help?
— Begin quote from Gene;495358
What was the original problem?
What is the part number of the ice maker you installed?
What is the complete model number of the refrigerator?
The heat element shorted out so I changed the unit. Its an Amana ARS9187A. Th ice maker is WPL D7824706Q.
Make sure the water feeding tube into the ice maker is not frozen.
The model number you posted does not come up. Verify and repost it please.
The lines are not frozen. The model is ARS9107A and the ice maker is D7824706Q. I just took everything apart and cleaned and checked to be sure it was put back together properly. No luck.
i have a Maytag Neptune Model MDE6700AYW and i get an E5 code can you tell me what i need to repar it. the normal drying cycle went on it a while ago but i could dry my clothes on the time cyle but now i get nothing except the E5 code
