ice maker
I have a Hotpoint refrigerator CSX24XKC. The water dispenser dispenses water but no water is getting to the ice maker. I checked all of the hoses to make sure none were frozen and also replaced the dual valve and still no water to the ice maker. The ice maker does turn. What do you suggest is the problem?
Hi.
First check the water line from the valve for cracks and if it’s OK - replace the icemaker WR30X10093
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=203802
Thank you. Post the results.
Simon.
