Ice/water dispenser not working
Refrigerator will not dispense ice or water. Light bulb comes on at dispenser, ice door will open, lights on control panel work fine. You can hear the micro-switch click when the dispenser arm is pressed. Water filter appear to fill with water after being removed and replaced.
Are there any tests to rule out the contorl board on the front of the unit? It looks like on this unit you have to order the touch pad and contorl board as one unit.
