No water or ice thru door dispenser
The dispenser unit does not dispense ice or water. The ice maker in the freezer is still working and makinng ice cubes.
I checked the water line and have good pressure. I also check the continuity on the water inlet valve (both red and blue) it was ok. I did not know to check voltage at the time.
None of the functions on the door interface panel work, no light, temp settings, temp displays. Unable to select water, crushed, cube, etc. as the indicator lights to not work. Also when I plugged the fridge back in the display started blinking 00…0…00.
Dont know if I should replace the dispenser assembly or the main control board.
Thanks for anyones help.
