I am having problems with Ice continuously dispensing. I have taken apart the front panels and cleaned everything but still have the problem. I notice the auger is continually spinning when ever the door switch is closed. I have seen some suggestions of a couple of controller boards being the possible problem, but didn’t find the ones for my model. Any suggestions or help would be greatly appreciated.
Actually I found that the Auger goes intermittently. Would this be the micro switch or possibly one of the control boards. Again, any help would be greatly appreciated.
Thanks!
I have a Monogram GE fridge. Ice maker auger is starting/stopping randomly. I have done some research and it seems is the motherboard. Unlucky nobody replied to you with comments. Could you tell me if you fixed the issue? Thanks
