IceMaker Help
My icemaker quit working and I’m trying to fix it my self. In looking around this forum I found some troubleshooting steps to take. I took the cover off the motor and when I tested at the N & L points on the motor, I am only showing 34.5VAC and if I am correct, I should have 120VAC at the these points.
I tried searching for further steps on what to do next but am not having any luck and I am stuck at this point and don’t know where to go next. Can someone please point me in the right direction. Thanks for any and all help!!!
If you close the left flapper door, close the door switch and verify the optics switch is turned on, you should get 115 volts at the icemaker.
If the optics are blinking, replace the optics.
