My igniters on the right side of my Viking stove (6 burners, grill) weren’t clicking most of the time so I had to light the burners with a match. I swapped the spark module from the left side to the right side (left side worked fine). Igniters fired and I ordered a new spark module to put on the left side.
The problem is some burners won’t stop clicking:
Burners are (G)rill (F)ront, (B)ack
Burner F works fine.
Burner B keeps clicking unless all burners on or just F is turned on
Burner G clicks unless all burners on
I swapped the igniter of back burner with a known working one and same thing. I looked at the wires for signs of wear, but they looked okay. I checked the ground on the spark module and the wiring and it looks okay. I swapped Front burners wire to the back burner, same issue.
Any ideas? Could it be the igniter switch? That is all I can think of. But seems unlikely 2 of them are bad.
