Took the left front burner apart to give it a good cleaning. After putting it back together I now have the igniter clicking on both of the front burners when the left front one is on. When the right front one is on, as well as the two back ones, everything is fine. It’s pretty obvious that my messing with the left front one caused the issue. As a side note the threaded nut that holds the burner base in place will not tighten because of stripped threads.
Any ideas what the issue might be? My first thought is that maybe there is moisture in the igniter because of my cleaning it up. Second thought is that maybe the stripped threads not allowing the base to be secured is the issue. Any suggestions appreciated.
Len
