Igniters keep clicking after burner lights
When burners or lit the clicking of the igniters continue. What would cause this? Would it be a single igniter, although seems intermittent too me, or a spark module?
Ron
Then my guess would be, that the infinant switches or the spark module are getting stuck on ignite. That is only my educated guess, as I said I’m not that familiar with your model. Thee are several posts on this site that tells you how to test components. Or call a local tech to check it if you aren’t comfortable doing the tests yourself.
Nat
