Water Does Not Shut Off When Entering Machine And Does Not Agitate. But Will Spin Out,
Help
So if you turned it on a regular wash and walked away, it would overfill the tub? If that is the case it is going to be a problem with either the presure switch or the hose to the pressure switch. Do you use bleach regularly, also I need a model#…
No I Don’t Use Bleach Too Often The Model# 41798702891
Because you don’t use bleach regularly, I am suspecting that the end of the pressure switch hose is clogged where it connects to the tub… The model# you gave is not a model# for your machine, There will be a sticker with model# and serial#, usually if you open the lid it is there, maybe on the side panel of the machine
On the front bottom of the machine, there should be 2 screws at the bottom, you’ll need to take that front cover off. the hose will be a small clear hose attached to a nipple on the outer tub. pull the hose off the tub and look for brown color at the end of the hose. let me know what you find
I will let you know ASAP waiting for my son to get home from work to do as you suggested. Thanks
