I need to replace the rubber boot seal and apparently that involves removing the service panel and control panel. Anyone have instructions on these procedures?
[SIZE=3]First you have to remove the top by removing three screws on the back and the screws that hold the trim on the front. Then remove the detergent dispenser and remove the screw behind it. Then remove the screws at the top of the control panel. Then reach into the washer from the top and press in on two clips that hold the control panel in on the right hand side. For more on this visit http://www.appliance-repair-it.com/GE-front-loader-washer.html[/SIZE]
