Hi, how do I raise the top of this washer?
[SIZE=3]First you have to take the front off by pressing in on two clips between the front and the top. Then remove two screws that hold the top on. For a picture to show where the clips are use this link http://www.appliance-repair-it.com/GE-washer-disassembly.html[/SIZE]
Trying to replace control panel cant figure out how to get old one off? took screw out of bottom of end cap the whole top is loose but end cap seems to be holding it .What is the secret???help!! DAVE:eek:
