inner glass in electric oven needs replacing
My wife spilled hot liquid on the oven door while removing a dish being cooked. The glass on the inside is cracked pretty good and needs to be replaced. I looked at the door. There are six screws that I can see. Phillips head and very short approx 1/4/ inch long. I thought if I removed them, the overn door would come apart and allow me access to the broken gleass. No such luch, so I replaced the screws and am looking for hepl for someone who has had this experience and can guide me in this process.:slight_smile:
Thank you.
Paul Gesche
Worked fine a few weeks ago - then took longer nd longer for over burner (long blue flame under oven to come on. Could lite witha match - but now that does not even work. What part do I need?
thanx
sam
:slight_smile:
