Oven door inner glass broken -
New guy. Spilled liquid from roaster pan while loading pan into pre-heated upper oven. Immediately cracked the inner glass on the oven door when the liquid contacted the 400 degree surface.
Found glass part on-line but not sure if there may be further damage - other glass, gaskets to be replaced, etc.
Also, I do not have a comprehensive users manual, only a "how to enjoy your double oven" new owners book. No parts list, no diagrams, etc…
Not sure how to go about taking door off. Removed 6 phillips head screws from the inner door surface facing. Inner panel does not "lift out" readily. Appears door needs to be:confused: lifted off and then ???
Note "Fossil" - I’m not the most able mechanic or fixit guy, but I am very quick to learn and listen well. Any help or hints would be appreciated.
Thank you.
