Intermittent Oven Temperature Control
The oven on our gas range will start and heat to the set temperature but then may or may not control at the set temperature. From reading, it seems to indicate a faulty igniter, but the intermittent nature of the range operation raises the question about the possibility of some other source of the malfunction.
Help would be appreciated!
