Intermittent Squeaking
My Maytag will start and run quiet then squeak very loudly then stop and then start squeaking again, I’ve replaced the belt and drum rollers, any ideas please help
Hi.
Most likely you need to replace the idler arm and the pulley.
See #19 and #21 on the diagram #6.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47870
Thank you.
Simon.
