My washer still pumps water, but makes a clicking noise and does not agitate or spin. I am assuming that this is a transmission problem. Is there a belt or something that I can replace?
Thanks,
I did some checking and realized that the fact that the pump was working did not rule out a bad coupling. It was in fact the coupling and I put a new one in (my 4th one on this machine). The good news is that now the plastic pieces of those couplings have a metal insert, so hopefully it will last a bit longer than the others.
Glad you got it fixed. Four couplings is rather a lot, but with the metal inserts hopefully this one will last a bit longer.
Thanks for the update.
