iS THE BEARING AND SEAL OF THE OUTER TUB (PLASTIC) REPLACEABLE WITHOUT REPLACING ENTIRE TUB? IF SO HOW DOES IT COME OUT AND WHAT PART NUMBER DO I ORDER.
No, you do not have to replace the whole tub. You can find the complete instructions in the [Maytag Technical bulletin](http://www.servicematters.com/maytag_library/docs/RS3100007R0.pdf"]Service manual[/URL]and in the [URL="http://www.servicematters.com/maytag_library/docs/TDL-0023A-B.pdf).
Here are the break down diagrams for the Amana washer http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=649178&&model_id=22193
