is washer totalled?
out of balance load broke one shock…after replacing there seems to be a noise racket coming out of the spider area of rear inner drum during spin cycle and water dripping fairly rapidly from area between the front outer drum and where the center weight is attached. is my washer toast?
Probably so.
Check your warranty and see if the basket and other parts are covered. Then call Frigidaire and see what they will do for you.
You will still need to pay for labor costs even if Frigidaire supplies the parts, so it may well be time to replace the machine. If so, get a no-frills top loader and you will be much happier.
